Watts Per Kilogram Calculator
Understand your power output in relation to your weight. Use our watts per kilogram calculator to find how you compare to others.
Find Your Watts Per Kilogram
Enter your information to find your watts per kilogram.
Enter Your Information
Beginner User:0.0
Experienced User:0.0
Your Watts/Kg:0.0
M
Tu
W
Th
F
S
Su
Sun
Mon
Tue
Wed
Thu
Fri
Sat
Week 1
2:55
201
Sun
Mon
Tue
Wed
Thu
Fri
Sat
Training Plans for Your Needs
Get access to +100 training plans with TrainerRoad or build your own custom plan, specific to your events and goals with Plan Builder
Beginner vs Experienced Cyclists Watts Per Kilogram
Watts per kilogram is just one of the ways cyclists measure performance and regularly leads to comparisons.
What are Watts Per Kilogram?
Watts per kilogram or power-to-weight ratio is a measurement of your power on the bike, in relation to your body weight. It’s expressed as watts of cycling power produced per kilogram of body weight, abbreviated as W/kg. It directly affects performance, especially on long, steep climbs.
In general, larger cyclists can put out more power than smaller ones. But power doesn’t tell the whole story because lighter athletes require less energy to overcome gravity when the road tilts upward. Power-to-weight ratio can offer a more reasonable way to compare different riders’ abilities than by looking at power alone. More importantly, it gives you a nuanced way to understand your abilities and changes in body weight in relation to performance.
However, watts per kilogram might be less important than you might think. It’s most important as the gradient becomes steep. On flat or rolling terrain, aerodynamics and raw power play a massive role. At speed, almost 90% of your power is used to overcome wind resistance. That said, increasing your power-to-weight ratio means that you have a greater proportion of lean muscle mass and a stronger aerobic engine. Your W/kg directly influences your climbing ability and is a good metric of general cycling fitness.
Watts
Watts are a measurement of power. You can think of this as a way to gauge how much work you are doing while riding a bike. In simple terms, power is equal to your torque multiplied by your cadence. Torque is the amount of force you generate, and cadence is the speed you turn the pedals.
Metrics like heart rate and speed are subject to outside influence, while power is objective and comparable in any condition. Technically speaking, a watt is a measurement of energy transfer measured in real-time while cycling with a power meter. Most commonly, the watts in W/kg refers to your sustainable power (FTP).
Kilogram
The kilogram is the other half of W/kg and is fairly straightforward. It is your body weight measured in kilograms. Our calculator will automatically convert pounds to kilograms for you.
How Do I Improve My Watts Per Kilogram?
You can improve your power-to-weight ratio in two different ways—increase power or decrease weight. We recommend focusing on the power side of the equation first because aerodynamics and power are usually more important than losing weight. The best way to increase your FTP is by following a structured training plan.
TrainerRoad has over 100 training plans to match your experience, schedule, and goals. As your aerobic energy system grows strong, so will your maximum sustainable power, and as a result, your power-to-weight ratio will improve.
But what about losing weight? For many cyclists, weight loss happens naturally throughout a training plan. For others, losing weight requires additional strategies like maintaining a healthy diet. It’s important to note that every cyclist’s body is highly unique. Instead of solely focusing on weight, we recommend working to optimize body composition.
Excessive weight loss can negatively affect your power-to-weight ratio by reducing muscle mass, which will decrease your power production. Our advice is to view weight loss in the context of your overall health and wellbeing. Losing weight may be a sensible way to improve your Watts/kg, depending on your body composition. However, if you are already very lean, it’s likely to be detrimental to your improvements in power and performance.
